How can I change the font size and title of the Legend?
How can I select all the 3D Objects that are assigned to a selected Resource?
Is there a way to automatically subdivide 3D Objects based on Grids or Levels?
How do I import Grids and Level lines into SYNCHRO Pro?
Is it possible to show a Dynamic Legend that only displays colors active in the 3D View?
How can I make a 3D Object transparent in the 3D View?
How do I change the order of Legend?
When I select any Task, why are all the Resources assigned to it are being automatically selected?
Why is the 3D Object disappearing when I subdivide it into multiple splits?
