Is there a way to display progress rate as a percentage based on a reference date?
How can I assign 3D Objects to Resource based on matching Properties or User Fields?
How can I see Cost performance Index (CPI) as a column in the Task list?
Can we set Appearance Profiles within SYNCHRO Pro, that were defined in P6?
Is it possible to group 3D components using a 3D User Field, in order to create Resources?
