Scenario: The display of the timeline in the exported animation is too small to read.
Example:
Solution (Workaround) : This will change the font size not only in your animation, but also on your timeline display (side effect).
1. First click on the gears at the very top left of Synchro 4D (Options Icon).
2. It will take a few seconds for the new window to open. Then Select "Gantt Chart" and "Font". Play with this font size until you are satisfied by checking the animation preview.
3. Once you have created your animation with the desired timeline size, you will need to go back and return the Gantt Chart timeline size back to its original size.
