How can I import Reality Meshes or Point Cloud models in SYNCHRO 4D Pro?
SYNCHRO 4D Pro doesn't support native Reality Data. However, you can convert the data into a mesh format like FBX or OBJ, which can be directly imported into 4D Pro. Ensure that all textures files are located in the same root folder as the mesh.
Refer to this wiki for more information about Reality Data in SYNCHRO Control.
