The following 3D file formats can be imported directly into the latest version of SYNCHRO 4D Pro.
Product: |
File Extension(s): |
Version(s): |
Note(s): |
ACIS |
SAT, SAB |
up to 2023 | |
Alias Wavefront |
OBJ |
All Versions | |
AutoCAD |
DWG, DXF |
R14 - 2022 | |
Autodesk |
DWF, DWFX |
up to 2012 | |
Autodesk 3DS |
3DS |
Any | |
Autodesk FBX |
FBX |
6.0 - 7.5 | |
Autodesk Inventor |
IPT, IAM |
Up to 2024 | |
Bentley iModel |
I.DGN |
1.0 | |
Bentley iModel 2.0 |
.BIM |
For SYNCHRO 4D PRO license only | |
Bentley MicroStation |
DGN |
V7, V8, V8 XM, V8I, V8i (SELECTseries 2), V8i (SELECTseries 3), V10 (CONNECT) |
SYNCHRO 4D Pro Plugin is available for MicroStation CONNECT Edition |
CATIA V4 |
EXP, DLV, MODEL, SESSION |
up to 4.2.5 | |
CATIA V5/V6 |
CATProduct, CATPart, CATDrawing, CATShape, CGR |
Up to V5_6R2023 | |
Collada |
DAE |
up to 1.5 | |
Dassault Interchange Format |
3DXML |
Up to V5-6 R2019 (R29) | |
GL Transmission Format |
GLTF, GLB |
2.0 only | |
HOOPS stream file |
HSF | ||
I-deas |
MF1, ARC, UNV, PKG |
up to 13.x (NX 5), NX I-deas 6 | |
IFC |
IFC |
2x, 2x2, 2x3, 4 | |
IGES part files |
IGES, IGS |
5.1 - 5.3 | |
Navisworks |
NWF, NWC, [NWD]* |
2017-2024 |
via SYNCHRO 4D Pro Plugin for Navisworks. *IMPORTANT: NWD can be exported to SPX, but does not support future model updates via Synchronise From |
Parasolid |
xmt_bin, x_b, x_t, xmt_txt |
up to v35.1 | |
ProE/Creo |
PRT, ASM, NEU, XAS, XPR, |
Pro/Engineer 19.0 to Creo 10.0 | |
Revit |
RVT |
2017-2024 |
via SYNCHRO 4D Pro Plugin for Revit |
Rhino |
3DM |
4, 5, 6, 7 | |
SketchUp |
SKP |
v7, v8, 2013-2020 | |
Solid Edge |
ASM, PAR, PWD, PSM |
V19 - 20, ST - ST10, 2019 to 2023 | |
SolidWorks |
SLDASM, SLDPRT |
up to 2023 | |
STEP part files |
STEP, STP |
AP203, AP214, AP242 |
Geometry ONLY |
Stereo Lithography |
STL |
All versions | |
UGS JT |
JT |
up to 10.6 | |
Unigraphics NX |
PRT |
V11 to v18, NX to NX12, NX1847 Series to NX2212 PRT Series | |
Universal 3D |
U3D |
ECMA-363, 1st, 2nd & 3rd editions | |
VDA-FS |
VDA |
1.0 - 2.0 | |
VRML files |
VRML, WRL |
V1.0 and V2.0 (VRML'97) | |
3D PDF, PRC |
PDF, PRC |
All Versions |
