3D, (3D) Resources and Tasks
Assigning (3D) Resources to Tasks
Synchro Challenge
- If you move the focus time on “Structural Piles” task, what do you see after Pile resources are assigned to the task?
- How do I select the Assigned Resource from this “Structural piles” task? And how do I Isolate Select the Assigned (3D)Resources?
- What controls the color of the Piles during the task?
- Is it possible for me to add Growth simulation, how was left/right/front/back determined?
Understand Resource Appearance Profile
- System Profiles/Action: Install, Maintain, Neutral, Remove, Temporary
- Start, Active, End Appearance
- Under Active Appearance: Color, Growth, Transparency, etc.
- Important!
When Resource(s) is/are assigned to Task(s),the selected Resource Appearance will be
assigned to the Resources.
*Pay attention to position of Focus Time
Create Resource Appearance Profile for Pile caps and Assign
- Navigator ribbon Resource → Appearance Profile
- Right-click to add new Resource Appearance Profile “Foundation Works”
- Action: Install
- Active Appearance
- Color: blue
- Growth: left to right
- Assign “Pile Caps” resources to the task
Make sure “Foundation Works” R.A.P. is selected
Drag “Pile Caps” resource and drop on the task
Check your work
- 3D Resource column on the “Pile caps” task has turned to 1
- Right-click on the “Pile caps” task, Select Assigned Resources
- Right-click in 3D View → Filters → Isolate Selected then ESC to un-highlight
- Step through the timeline on the target task to check if the desired Resource Appearance Profile has been applied
Synchro Challenge
- If you move the focus time on “Pile Caps” task, what do you see after Pile caps is assigned?
- How do I select the Assigned Resource from this task? And how do I Isolate Select the Assigned (3D)Resources?
- Does the appearance match what you expect?
- For Growth, how was left/right/front/back determined?
- How to change the Appearance profile that was used for Structural Piles?
Create Resource Appearance Profile for Concrete slab and Assign
- Navigator ribbon → Resource Appearance Profile
- Right click to add new R.A.P. “Concrete slab”
- Action: Install
- Active Appearance
Color: light green
Growth: left to right - Assign Concrete resources to concrete tasks
Before you assign, make sure “Concrete Slab” R.A.P is selected
Drag Concrete (3D)resource and drop on the target tasks
Summary
- What is resource appearance profile?
- What are the four system appearance profiles?
- What are the four actions for appearance profiles?
- Can you name a few construction activities that reflects those four actions?
- In active appearance, what can you adjust in general?
- How to assign appearance profile to Resource?
- What is the correct workflow to assign resource(s) to task?
- What is the Resource – Task relationship?
- One to many
- Many to many
- Many to one
- How do we unassign Resource(s) from Task?
