3D elements sliced in Modeler are not visible in 4D Pro if 3D elements were created in 4D Pro
If 3D elements which were imported in 4D Pro directly are sliced in SYNCHRO Modeler, then these slices will not appear in SYNCHRO 4D Pro - this case is not implemented yet.
Create 3D elements via connectors. If such elements are sliced in SYNCHRO Modeler and synchronized, then the slices will appear in 4D Pro.
