Scenario: While using Windows 11 we are unable to select a date range when printing from SYNCHRO 4D PRO. In Windows 11 we are presented with a new print window that doesn't allow for any modifications outside of which printer to send it to. On Windows 10 we are able to see the proper interface for printing in Synchro 4D which allows for more configuration options. Is there a way to modify this on Windows 11 to use the older print settings window?
The user can see the below print dialog window.
This print dialog window comes in Windows 11 OS and the solution for this problem is available here:
To restore the Synchro print interface, please
click on link Restore the Legacy Print Dialog in Windows 11 22H2
