In order to run the SYNCHRO 4D client, the following Minimum, Recommended and Enterprise Edition system specifications are outlined below.
| Minimum | Recommended | Enterprise | Notes | |
| Processor | 2.8 GHz Quad Core | 4 GHz Octa Core | 5 GHz Octa Core | Only 64-bit (x64) processors are supported. |
| Memory (RAM) | 16 GB | 32 GB | 64 GB or greater | |
| Hard Disk Space |
The expected disk type is SSD, preferably with NVMe. The Small Office models are referenced in the Tutorials. The Logistics Models provide a graphics library of plant equipment, that may be used as part of your SYNCHRO 4D project plans. |
| Graphics Card | 4 GB | 16 GB | 32 GB, 64 GB or greater | NVIDIA CUDA support is expected. |
| Display |
| Operating System |
Only 64-bit (x64) operating systems are supported | ||
| Others |
Network connectivity is required for License activation and working with cloud-hosted Bentley Infrastructure Cloud Projects (previously SYNCHRO Control). | ||
