Included below is a list of bug fixes for 6.2 hotfix (6.2.3.0)
Pro/ OpenViewer/ Scheduler
- Crash on inserting new task under another task with assigned codes
- Performing subdivision on certain objects hangs/ takes too long and causes crashes
- 3D Filter > User Field > Match All Fields not working in 6.2
- Date user fields do not export on synchronize to ASTA
- Crash when resizing Task view
- Crash after adding intro in Animation.
- Crash on attempt to open Task properties> Risks in OVR
- Crash on synchronise from MSP XML
- Deleting SYNCHRO logo in Export Animation UI leads to crashes
- SP file is corrupted in case problem with cached Document files
- Resource Units Total calculates incorrectly when there are multiple resource rates
- Object disappears after maintain profile if earlier than planned dates for finished install task
- Ambient Occlusion 'strobing' effect not working properly
- Resources creation is executed infinitely
- FBX fails to import textures
- Crash after pressing Save in AVI Export if Content tab was not seen before
- Crash when calculating values for table groups in 3D table > Resources column
- SPX from i.dgn Synchronization issue
- Crash on import IFC that uses «Solid Element Operation» in Archicad
- LDAP authentication problem
- Hide user fields when Read permissions were set to None
- ALAP constraint results in incorrect dates
- Empty Gantt chart on import SP with costs
- SPX Synchronisation issue found in 6.2
Link:
- Link crashes on attempt to insert new task as child to tasks which cannot be summary
- WEB API Script issue
Workgroup Project
- Resource creation - automatic transaction rollback issue found in 6.2
Plugin for MicroStation
- DGNs appear to be off scale
- Differences between SPX exported from MicroStation plugin v5.0.1.1 VS v6.1.1.1 or v6.1.2.3
- Different 3D Views in MicroStation and in SYNCHRO Pro
- All 3D objects hidden due to large coordinates in MicroStation
- X-reference file names are too long when exported from MicroStation CE plugin
- Redundant geometry exported from MicroStation Connect Edition plugin but not exported by v8i plugin
ProjectWise
- Import SP files from ProjectWise does not work
- Update ProjectWise SDK
- Importing .SPX from ProjectWise returns an error
- Cannot login to ProjectWise through IMS authentication
- P6 XML import through Import > ProjectWise is defaulting to MSP XML
- Cannot open .SPX from ProjectWise
- Issue with PW DLLs and installation
