2019.2 Release Notes - SYNCHRO Pro
         SYNCHRO Pro        SYNCHRO Scheduler  SYNCHRO Open Viewer       SYNCHRO Plug-ins
Update is available hereQuick Links & Highlight Video
Visit Software Downloads in the Bentley CONNECTION Center.
Look for brand SYNCHRO, then click Apply to find the latest updates for SYNCHRO Pro, SYNCHRO Open Viewer, SYNCHRO Scheduler, and the Plug-ins.
    Watch this video for highlights of new features and major improvements.
    Direct Download links
    SYNCHRO Pro Plug-ins
    "Trial Expired, SYNCHRO 4D Pro" or "SYNCHRO 4D Pro Trial" message window for existing SYNCHRO Pro users
    SYNCHRO 4D Pro is a new license introduced to this release that enables the iModel functionality in addition to the traditional Pro license, which is why users upgrading to 2019.2 will get a notification about a 7 day trial for the SYNCHRO 4D Pro license. SYNCHRO Pro will continue to work as it always has after the 7 day for 4D Pro (iModel) trial ends. Since the names of the licenses are so similar, this may cause some confusion.
    SYNCHRO 4D Pro includes beta features for iModel integration. User may be prompted with a message window after upgrade which says “SYNCHRO 4D Pro trial” message window. User can cancel or close the message window to proceed with the trial. SYNCHRO Pro will continue to work as normal. After 7 days when 4D Pro license expires, SYNCHRO Pro will detect that entitlement is expired and will disable Options>Plugin modules setting for iModel so that the license is not checked for on opening Pro anymore and the dialog about expired license will not be raised again. User can disable this setting earlier if they do not want to see trial license message or use iModel features in Options> Plugin, uncheck iModel.
    The trial period notification the user receives is for the SYNCHRO 4D Pro license (iModel related features) only. SYNCHRO Pro will continue to work as it always has after the 7 day for 4D Pro (iModel) trial ends.
    Major Improvements and New Features
    Other Improvements
    3D
    Resources, Resource Statuses, Resource Groups
    Scheduling
    Tables, Grouping, Filtering
    User Interface
    Performance / Memory Expense Reduction
    Integrations (Import / Export / Synchronization)
    Plug-ins
    Bugs squashed
    Resources
