SYNCHRO Pro 2019.2 hotfix (6.2.4.2) was released on Feburary 17, 2022 in response to mitigation of the potential log4j vulnerability found in SYNCHRO Pro. Fixes for defects are also included.
This release includes the following products and versions:
- SYNCHRO Pro (6.2.4.2)
- SYNCHRO Workgroup Project (6.2.4.2)
- SYNCHRO Link (6.2.4.2)
- SYNCHRO OpenViewer (6.2.4.2)
- SYNCHRO Scheduler (6.2.4.2)
Plugin-ins for MicroStation, Navisworks and Revit don't require updates hence are not included in the release, and 6.2.3.0 remains as the latest for 6.2 plugin users.
Quick links:
Upgrading and Downloads:
Click the links below to download the latest version or visit Software Downloads in the Bentley CONNECT Center. Make sure you
Improvements and fixes
Fixes for Security and Defects
- Remove 'render_farm_client' from SYNCHRO Pro installer. Official advisory and SYNCHRO wiki on this topic will be available later:
- Regenerate security certificates for SWP
- Add DLLs to Link installer/zip for Primavera and IFC plugins
- Review SynchroAPITrace class - avoid tracing parameters passed by users
- hanged after reconnect to SWP project
- update IFC4 schema to use ISO 16739-1:2018
- Add Start and Finish columns for Target Task in Add/Delete Links dialog (6.2.4.x)
- Crash on markup creation
- IFC: integer is out of range. cannot create building elements
- 6.2.x does not support IFC 4.0.1 and IFC 4.0.2
- Cannot rename Baselines by double left-clicking on it
- Out of sequence tasks may change finish time after editing of schedule
Resources
Contact Details
