Plugins
- ProjectWise: ability to change datasource on SynchroniseTo
- ProjectWise: use document GUIDs for synchronization
- Added plugin support for Revit 2021
- Added plugin support for Navisworks 2021 and Navisworks Simulate 2021
Bugs squashed
- Cost code not imported from Excel unless Activity or Resource Code also imported
- 3D Filter > User Field > Match All Fields not working 6.2v
- Cannot synchronise IfcSpaces
- Resource Cost incorrect when effective date occurs in middle of task
- Could edit notes created by another user
- Performing subdivision on certain objects hangs, crashes
- Objects missing on import IFC4 vs IFC2x3
- Growth Simulation with "Pause during Non-Working Time" did not work for Resource Groups
- Actual Cost in EVA Graph didn’t match ACWP in Gantt Chart
- 3D View Properties>Filters>Unfiltered Objects Settings were not saved with Viewpoint, Layout, Animation Keyframes
Performance / Refactoring/ Model quality improvements
- Improve removal of 3D and reading old SP files
- Accelerate 3D filtering
- Optimize working with data containing a lot of UF values
- Refactor some internal data structures to reduce memory expenses and improve performance when working with huge data
Integrations (Import / Export / Synchronization)
- ProjectWise Design Integration CONNECT (v10)
- iModel 2.0 (BIM files): import and export
- SPM file exporter
- Added support for recent 3D CAD formats:
- ACIS 2019
- Autodesk Inventor 2020
- CATIA V5/V6 V5-6 R2019 (R29)
- Parasolid v31.1
- ProE/Creo 6.0
- SolidEdge 2019
- SoildWorks 2019
- UGS JT v10.2
- Unigraphics NX 12.0
- Asta Powerproject v15 support
- Safran: support import from v7.3
- Improve synchronization to Primavera P6 PPM SQLite-based
