| Product(s): | Bentley SewerGEMS, WaterGEMS, WaterCAD, HAMMER, StormCAD, CivilStorm, PondPack, SewerCAD |
| Version(s): | Connect Edition, V8i |
After validating or computing a date/time type query your results return all elements (ex. 21 of 21 elements returned) when you know there should be fewer than this.
The SQL language requires that you put a # sign (a pound sign) both in front and behind the date when performing a query on this type of data value.
