| Product(s): | WaterGEMS |
| Area: | Modeling |
In Skelebrator, how can I protect elements which are part of control sets from skeletonization process, so that Skelebrator does not remove them and break the controls?
Elements which are part of controls sets like pipes or junctions, should be retained from the skelebrator process. This technote explains how to protect such elements in skelebration process.
To protect the controlled elements from skelebrator process, follow the below mentioned steps.
Using Skelebrator to reduce the number of pipes in a model
How do you use Skelebrator on only a certain selection set of elements?
Is there a recommended level of Skelebration for different modeling conditions?
