This article provides a list of in-depth TechNotes and FAQs for Bentley WaterCAD and WaterGEMS products.
To search within this page, press [Ctrl]+F.
Frequently Asked Questions
WaterGEMS and WaterCAD General FAQs
WaterGEMS For ArcGIS Pro and WaterGEMS for ArcMap FAQ
Overview of WaterGEMS for ArcGIS Pro
Modeling
WaterGEMS and WaterCAD Data Import FAQ
Building and updating a model using ModelBuilder
Carbon Emission Analysis and Energy Cost Analysis
Creating controls, conditions, actions and controls sets
Creating formula-based User Data Extensions
Energy Cost and Energy Management
Automatic processing of results (or other) data using an extensible data exchange framework
How does the Pressure Reducing Valve (PRV) work?
How does the Pressure Sustaining Valve (PSV) work?
How to edit demands, unit demands, or a subset of demands globally
Importing A CAD (eg. DXF or DGN) Drawing Using ModelBuilder
Importing Demands From A Spreadsheet
Importing Time Series Data Using ModelBuilder
Modeling Air Valves At High Points
Modeling a Connection to an Existing System
Pump Station and Pump Combination Curves
Running a Criticality Analysis
Scenario and Alternative Management
Setting Up Pressure Dependent Demand
System head curves with no downstream storage
Understanding Automated Fire Flow Results
Troubleshooting
Troubleshooting and Understanding LoadBuilder
Troubleshooting "Network Unbalanced"
Troubleshooting negative pressures at pumps, junctions, & other node elements
What's New
New Features and Enhancements for OpenFlows products
OpenFlows Product TechNotes And FAQs
OpenFlows Water Solutions on Bentley Website
