| Product(s): | SewerGEMS, StormCAD, CivilStorm |
| Version(s): | 08.11.XX.XX and 10.XX.XX.XX |
| Area: | Modeling |
When computing an constraint based design with the GVF-Rational solver the following warning user notification appears:
"Inlet Type should be set to a valid Catalog Inlet before the inlet's opening length will be designed."
This message is returned when running an constraint based design with the GVF-Rational solver and a catch basin has the property "Design inlet opening?" set to true, but the inlet type is not set to a catalog inlet. This message informs you that the program is set up to design the inlet opening, but it cannot do that because the inlet type is not set to one that supports different inlet sizes.
There are to options to fix this:
1. If you do not wish to design the inlet in question, set "Design inlet opening?" to "False"
2. If you want to design the inlet, set the inlet type to a catalog inlet with a valid list of opening lengths
