| Product(s): | PondPack, SewerGEMS, CivilStorm |
| Area: | Calculations |
How is weir flow calculated when using the Irregular weir option in a composite outlet structure, in PondPack, SewerGEMS or CivilStorm?
When using the Irregular Weir option (for example to model a trapezoidal weir, step-weir or some other irregular shape), the standard Weir equation is used:
Where
Q = Flow (cfs, m^3/s)
C = Weir coefficient (typically 3.0 ft^0.5/sec)
L = Length (ft, m)
H = Head (ft, m)
However, the program breaks up the calculation into multiple segments and adds those flows together for the overall weir flow at a given headwater elevation.
Below is an example of a trapezoidal weir with 4:1 (H:V) side slopes. This is broken into three separate segments, one for each of the side slopes with a head (h) based on the average depth in that segment, and one segment for the middle, flat portion. For more complex, non-trapezoidal cross sections, additional segments would be computed.
Blue: Weir shape / Red: effective rectangular weir segments
How do I input the elevations for an irregular weir cross section in composite outlet structures?
Modeling a multi-stage or step weir
Error with irregular weir outlet structure: Split flow not allowed for weir x-y cross section.
