| Product(s): | Bentley SewerGEMS, CivilStorm, StormCAD |
| Version(s): | V8i, Connect Edition |
| Area: | Output and Results |
Error on exporting storm-sewer model to Micro Drainage – Labels do not contain pipe numbering in the correct format.
MicroDrainage expects pipe labels to be in specific format - "[BranchID].[PipeIndex]", hence you will need to relabel the pipes in storm-sewer products to be in branch numbering format using tool Branch labeling (Tools > More > Branch Labeling). And then export the model as Microdraiange file it would work.
Or you could export MicroDrainage file using another option – Generate pipe numbers automatically on export, allowing software to relabel pipes on export.
Opening an InRoads Storm and Sanitary drainage database in Storm/Sewer products
InRoads crashes when viewing and editing a model imported from a storm-sewer product
