| Product(s): | PondPack, Civilstorm, SewerGEMS | ||
| Area: | Dataset | ||
| Original Author: | Kathy Wiggins, Bentley Technical Support Group |
Where does the data for the 'BUL70-71' and 'BAS70-71' Dimensionless Rainfall Curves come from? And what is the difference between the two?
The data for the rainfall curves comes from the Illinois state water survey bulletin 70 and 71. These are sometimes referred to as Huff Distributions and are dimensionless time, so you can apply both a duration and a depth (in contrast to the SCS types which are not dimensionless time and are locked to 24 hours).
The 'BAS' contains data that comes directly from this bulletin. The 'BUL' is derived from the same bulletin, BUT has more times steps (and is thus more precise). The 'BUL' includes interpolated values from Bentley, which are provided for better computer modeling purposes. It is best to use the more precise data set when modeling with our program.
Stormwater Conveyance Modeling and Design (book - starting page 98)
Modifying and adding entries to Engineering Libraries
How can I apply a rainfall depth or intensity to a dimensionless curve to create a storm event?
