| | Applies To | | |
| | Product(s): | PondPack | |
| | Version(s): | 08.11.01.56 | |
| | Area: | Layout and Data Input | |
| | Original Author: | Mark Pachlhofer, Bentley Technical Support Group | |
When I try to use a dimensionless Huff 10-50 2ndQ 50% or 50-400 3rdQ 50% distribution the following error appears:
"System.IndexOutOfRangeException: Index was outside the bounds of the array."
This is caused by these particular distributions in your engineering libraries not containing any data. This is a known issue (reference # TFS67055).
To resolve this, use the information below and copy then paste the information in to the collection
- Go to Components > Engineering Libraries
- Expand the 'Dimensionless Rainfall Curves' library by clicking the plus sign (+) to the left of it
- Expand the Bul70-71.xml library by clicking on the plus (+) sign
- Locate the appropriate distribution and click on it. You will notice there is information populated on the right side of the dialog box.
- On the right side of the dialog box click on where you see <Collection: 0 items> . You should now see an ellipsis. Click on it.
- In the dialog that appears, click the yellow edit button at the top, enter an increment of 0.01 and click OK.
- Check to make sure the dialog looks like the screenshot below. If you do not see "(%)" after the "Depth" column, it means your units are set to dimensionless (which expects values from 0 to 1.0 instead of 1-100 for percent). If you do not see the percentage unit, right click on the "Depth" column header, choose "Units and Formatting" and change the unit to be "%".
- Download the spreadsheet file from the link below and save to your hard drive.
- Huff Distribution 50 400 3Q 50%
- Huff Distribution 10 50 2Q 50%
Note: you will need to be signed in to download these files.
- Open the spreadsheet in an external application such as Excel, highlight all of the depth values (cells B2 through B102) and press CTRL+C to copy to memory
- Back in PondPack (see dialog above) click in the first cell under the "Depth (%)" column (row 1) and press CTRL+V to paste in the values from Excel.
- Verify that all the values pasted in - the last row should show a value of 100% next to the "synthetic time" of 1.0. (see screenshot below)
- Click OK and note that the right side of the Engineering Library should say "collection: 101 items" next to the distribution you just fixed. Repeat this process for the other distribution if needed.
Modifying and adding items to an engineering library
How to create a custom rainfall distribution
