| Product(s): | WaterGEMS, WaterCAD | ||
How can the number of pipes be reduced in a WaterCAD or WaterGEMS model?
To reduce the number of pipes in a model try to combine pipes that have equivalent diameters and roughness. The Skelebrator tool can help automate this and is available in WaterGEMS. If you have WaterCAD, you will need to upgrade to WaterGEMS to access Skelebrator.
Note: in the distant past, WaterCAD users could purchase Skelebrator separately, but this is no longer possible. Also, starting with CONNECT Edition Update 2 (10.02.00.43 and greater), the Skelebrator tool is no longer accessible from within the WaterCAD user interface. See more on Skelebrator in the articles linked to further below and in this video.
Note that when using Skelebrator, elements will be deleted in order to accomplish the skelebration. If you want to maintain separate scenarios in the same model for before-and-after skelebration, you'll need to first save separate models, and then use Submodel import. See this discussion and this article for more information.
Information on using Skelebrator can be found at the following link: Using Skelebrator to reduce the number of pipes in a model.
If you have hydrants, considering placing them on the main pipeline, and model the lateral losses using the embedded properties in the hydrant (rather than adding the extra lateral pipe.
You can also use Laterals and Customer elements to assign demands along the length of a pipe instead of creating extra nodes (which split the pipe). As of version 10.00.00.50, lateral link elements do not count toward your pipe limit.
You can also use isolation valves instead of valve node elements (like GPVs or TCVs) to model valves, as the isolation valves do not split the pipe (they "float" and are attached to / associated with the pipe). Meaning, instead of two pipes connected to a valve node, you would have one pipe associated with the isolation valve. If you have already imported isolation valves as another valve type such as a GPV or TCV, you can convert them to isolation valves using the Inline Isolation Valve Replacement tool in Skelebrator (in WaterGEMS).
Note that if you take advantage of the GIS-ID feature to keep your model in sync with your GIS, using the inline isolation valve replacement tool will result in a single pipe with both GIS-IDs from the two former pipes. So, if a change happens to these pipes in the GIS and you perform a sync-in (from the GIS to the model) in ModelBuilder, the single pipe in the model will receive the update for the two pipes from the GIS. If both of the pipes were changed in the GIS, a ModelBuilder sync-in will adopt the "last one wins" principle to determine which of the two changed pipes in the GIS are synchronized to the one pipe in the model. For this type of workflow, it is recommended that you use the Snapshots feature in ModelBuilder.
Series Pipe Merging in Skelebrator not working for pipes with zero diameter
Pipes not merging when using Skelebrator with series pipe merging
Customer Meter Elements and the External Customer Meter Data Manager
