Pipe fill or drain time in WaterGEMS and WaterCAD
 Product(s):WaterGEMS, WaterCAD
 Version(s):CONNECT Edition, V8i
 Area:Modeling
Is it possible to calculate the time required to empty or fill a pipe network in WaterGEMS and WaterCAD?
One of the underlying assumptions for the EPANET solver that WaterGEMS and WaterCAD is based on is that the pipes are always pressurized. Because of that, you will not be able to directly model a pipe emptying or becoming partially full.
If you're interested to know how long it takes for a tank to fill or drain, set up an extended period simulation (EPS) and let the tank drain or fill. You can then observe how long it takes for the tank to drain or fill.
A better way to model this type of situation is to use SewerGEMS. SewerGEMS allows for the modeling of partially-filled pipes that are running under gravity as well as pipes that are pressurized. In SewerGEMS, you would be better able to monitor the timing of when a pipe goes from the being under pressure to partially full, as well as how long it takes before the pipe is empty.
If you have PondPack, you could model this using the Pipe Volume pond type (or define the pond as an elevation-volume curve if you can determine the storage volume of the pipes in question at each elevation), with pond outlet structure set to the orifice(s) that release water. You can then use the Minimum Drain Time tool to see how long it takes to empty the pond.
You may also want to consider the transient impact of expelling all the air from the system: Modeling the filling of an empty pipe in HAMMER
If you only have access to WaterGEMS or WaterCAD, you could estimate based on the flow rate when the pump is on. If you anticipate the flow to slowly decrease as the pipe fills, you could estimate the fill time based on the average between the flow rate when the pump is on and the flow rate at the pump shutoff head (flow at zero head), along with the total pipe volume. Or, you could model the pipe volume as a fake tank element located a very short distance from the pump. The tank volume could be configured such that the tank top is set to the elevation of the top of the pipe and the total volume is equal to the pipe volume. This would enable you to see the gradual change in flow as the pump needs to add additional head as the pipe fills.
How do I find how long it takes a pipe to drain in CivilStorm and SewerGEMS ?
Modeling Transmission line priming starting from Empty conditions?
Time Required to Empty the System
