| Product(s): | PondPack | ||
| Area: | Modeling |
How do you connect a pond to a node, such as a junction or an outfall, in PondPack V8i and CONNECT Edition?
In PondPack V8i and CONNECT Edition, ponds are polygons. The pond outlet structures are modeled as a Pond Outlet Entrance node and a Pond Outlet link. The Pond Outlet link can be connected to a node, such as a junction or outfall. The screenshot below shows one such setup.
