| Product(s): | PondPack | ||
| Version(s): | CONNECT Edition, 08.11.01.xx | ||
| Area: | Modeling |
Does a user-defined hydrograph count toward my pond limit? (for licensing)
Problem ID#: 39313
In previous versions of Pondpack, the hydrograph queue node element represented a user-defined hydrograph and would count as a pond (when
checking the pond limit in your license). In PondPack CONNECT Edition and V8i, the user defined hydrograph option for a catchment does not count toward the pond
limit.
