| Product(s): | PondPack | ||
| Version(s): | CONNECT Edition, V8i | ||
| Area: | Modeling |
How can I find the total cumulative volume from infiltration for a pond?
Problem ID#: 62643
PondPack CONNECT Edition and PondPack V8i
In PondPack CONNECT Edition and PondPack V8i, you can find a report on the cumulative volume by going to under Reports > Report Builder.
PondPack version 10
In version 10, you can find the cumulative runoff volume for any hydrograph (including infiltration hydrographs) in Report Builder. After computing the model, click the report builder button (to the left of the dropdown list of graphs to view show in the red box in the screen shot below), then scroll down to the "Pond Routing" section. Look for the report called "pond infiltration HYG", click it and click the Preview button. At the top of this report, you'll see "HYG Volume = " near the top.
How to vary pond infiltration rate with water surface elevation
How Infiltration is calculated when using the "Infiltration Head / Depth" method
