| Product(s): | PondPack |
| Version(s): | CONNECT Edition, 08.11.01.56 |
| Area: | Output and Reporting |
Problem Description
Is it possible to create old PondPack style text reports?
Steps to Resolve
- Open the calculation options (Analysis > Calculation Options)
- Double click the active calculation option for the scenario that you are working in to open the properties
- For the "Show Status" property select "True"
- Select an output path in the "Report Output Directory" field just below it. This is the location the text file willl be saved in.
- After computing the scenario in question, you will find a text report in that folder, containing the same text reports that were available in the Report Builder of Version 10 and below.
What's new in PondPack CONNECT Edition?
Whats New In Pondpack V8i [FAQ]
