Windows 11, 10 and 8 compatibility with Flowmaster, Culvertmaster, and PondPack
  Product(s): FlowMaster, CulvertMaster, PondPack
  Version: CulvertMaster: 10.03.00.03 and higher
FlowMaster: 10.03.00.03 and higher
PondPack: 10.02.00.01 and higher
  Area:  Installation
Are CulvertMaster, FlowMaster and PondPack compatible with Windows 11, Windows 10 and Windows 8?
As of the versions mentioned above, FlowMaster, CulvertMaster and PondPack support Windows 11, Windows 10 and Windows 8.X, with the exception of FlowMaster 2025 and higher, which only supports Windows 11 and Windows 10.
Even if the Help and Readme included with the installation of some version numbers may not mention these as supported Operating Systems, these applications should work without a problem, and Bentley Technical Support will support a subscriber who runs into any issues with these operating systems. See more in the second article listed below. These operating systems may not have been available when these versions were released. Testing was done at a later point and as mentioned above, they should be expected to work without issue.
A note on .NET Framework 3.5
Although the .NET Framework 3.5 is used by these versions (see first article below), it will still work on Windows 11. .NET 3.5 is still supported by Microsoft until 2029. It is also included with Windows 11 as a feature but not turned on by default. During installation of these Bentley applications, they will attempt to enable it, but if that fails, the user can enable it via the Windows Control Panel.
A note on FlowMaster 2025:
In October 2025, FlowMaster 2025 was released (version number 25.00.00.982), and fully supports Windows 11 and Windows 10. As prerequisites, it requires .NET Framework 4.8 and the Microsoft Visual C++ redistributable version 2015-2022.
Platform Compatibility Matrix
Windows 11 Compatibility for OpenFlows Products
