How do I apply the 'Swamp Factor' when using the SCS Unit Hydrograph or the Tabular TR-55 methods?
 Product(s):PondPack, SewerGEMS, CivilStorm
 Version(s):CONNECT Edition, V8i
 Area:Data Input
How to apply the swamp factor when using the SCS Unit Hydrograph or the Tabular TR-55 methods?
The swamp factor is not entered directly in the software and is not used in the generation of runoff hydrographs. To account for swampy regions in a catchment area using TR-55 Tabular or SCS Unit Hydrograph methods, adjust the CN and Tc values accordingly.
In PondPack, the swamp factor is a variable which is only associated with the TR-55 Graphical Peak method which can be accessed by going to Analysis > Calculators > TR-55 Graphical Peak and Storage > Inflow
