| Product(s): | WaterGEMS, WaterCAD |
| Area: | Output and Reporting |
When attempting to validate a model in WaterGEMS or WaterCAD, the following red user notification appears:
"Failed to validate model. The model may be corrupt or contain incomplete information."
This is a generic validation message, which can happen in cases where an unexpected situation was encountered, with no specific validation message for it.
First, try upgrading to the latest version of the application.
Next, if you are using version 10.02.03.06 of WaterGEMS, WaterCAD of HAMMER, see this article about a known issue: Computing model saved in version 10.02.03.XX results in "Failed to validate model."
If upgrading doesn't help, or if you cannot upgrade, close the model and browse to where the model file are saved. Create a new folder and copy just the .wtg and .wtg.sqlite files into the new folder. Then open the model from the new folder location. If there is an issue with one of the supporting files, this may help.
If that doesn't help, try importing the database file into a new drawing by going to File > Import > WaterGEMS database or WaterCAD database, and selecting the database file. This can help if there is an issue with the .wtg file.
If that doesn't help, here are some things to check:
1) Pipes missing end nodes. Try running the "Pipes Missing Nodes" query in network Navigator
2) Issues with control conditions or actions. Under Components >Controls, check all conditions and actions, make sure they reference valid settings and element labels.
3) Problems with pump definitions. Check the pump definition for all pumps used in the model. Make sure the type of pump definition is correct and that the head/flow values are reasonable.
4) Problems with fire flow selection set. If you're computing an automated fire flow analysis, check the fire flow selection set in the fire flow alternative. Make sure the selection set contains valid elements.
5) Problems with active demand adjustment scope. Check the adjustment fields in your calculation options. If any are active, check the scope or try setting them to "none".
6) Problems with hydropneumatic tank control range. If your model has hydropneumatic tanks with "treat as junction?" set to "false" and "Constant Area Approximation" as the Tank Calculation Method, check to make sure that any controls et under Components > Controls match the "HGL (on)" and "HGL (off)" set in the tank properties. Ensure that the controls are set to use hydraulic grade and that the values match up. Click through each related control in the Controls manager, close the Controls Manager and try again. (reference known issue #877038)
7) User Data Extension set to use the Initial Settings alternative. As of version 10.04.00.108 of WaterCAD, WaterGEMS and HAMMER, there is a known issue (reference # 1019841) at least with PRVs, where a User Data Extension cannot be set to store its data in the Initial Settings alternative. In this situation you will currently need to delete and recreate the User Data Extension using a different alternative such as the User Data Extensions alternative.
8) Using Surge Tank and the combination of Logical Controls. When using the Surge Tank element in WaterGEMS, setting the Transient (physical) property ‘Has check valve?’ to true and combining it with logical controls in the Control Manager can lead to a “Failed to validate model” user notification. This issue arises due to a conflict between the check valve behavior and the logical controls applied to the system. This is a known issue and developers are working on it. It will be resolved in future versions.
If the above does not help, send the model to technical support for assistance.
Creating Controls - Conditions, Actions and Control Sets (V8i)
