| Product(s): | SewerCAD, SewerGEMS, CivilStorm, StormCAD, WaterCAD, WaterGEMS, HAMMER, PondPack | ||
| Version(s): | CONNECT Edition, V8i | ||
| Area: | Libraries/Catalogs |
The default engineering libraries appear to be missing. How can I restore them?
First make sure the original, default engineering library xml files are still located under the following folder (for Windows 7/8/10/11):
C:\ProgramData\Bentley\<ProgramName>\10\Libraries
Or for older, V8i versions: C:\ProgramData\Bentley\<ProgramName>\8\Libraries
If so, delete the Engineering libraries database per the link below and restart the program, which should point back to the correct locations of the .xml files:
How to Delete Engineering Libraries
If for some reason those .xml files aren't there, then reinstall the software. You may want to clean out the old related folders in the user profile after uninstalling, per this article:
How do I perform a clean uninstall and reinstall of the Hydraulic and Hydrology products?
