Product(s): | FlowMaster |
Version(s): | CONNECT Edition, V8i |
Area: | Output and Reporting |
How can I print multiple worksheets in FlowMaster at the same time? (so that I do not need to open them one by one and print)
Yes, you can print the Detailed report of multiple worksheets in batch:
1. Open all worksheets to be printed.
2. Right-click on one of the worksheets in the list view on the left pane then click "Print Selected Worksheets".
Note: Only open worksheets will print. Also the order in which all the worksheets are selected (by pressing the CRTL key) remains the same when printing. So if you want the worksheets in a specific order one after the other this should be ensured while selecting them all.
(Reference #44348)
Currently the batch print of worksheets only includes the detailed report. If for example you want to print cross sections of multiple worksheets, you will need to print them individually.
The ability to print cross sections or other types of reports in batch will be considered by Product Management for a future version. Reference # 1032185.
