What file types are supported for background layers in the standalone platform?
Product(s): WaterGEMS, WaterCAD, StormCAD, SewerCAD, SewerGEMS, CivilStorm, PondPack, HAMMER
Version(s): 08.11.xx.xx and higher
What file types are supported for background layers for the standalone platform for the water or storm-sewer products?
Backgrounds can be added using the Background Layers manager, from View > Drawing Views > Backgrounds
The supported file types include:
Background Maps (Google Maps)
Starting with CONNECT Edition Update 1, Background Maps can also be added directly in the Background Layers manager: How to add background aerial and road map images to your model
With your model's Coordinate System set, the background map will automatically align with the model.
World file support for background images
Some image formats support associated world files, starting with the CONNECT Edition release. When attaching a background image file that has an associated world file present, the image will now be spatially located automatically (ie. georeferenced).
Currently the following file formats support an associated world file:
The World file extension is based on the image's extension. One convention is to use the first and last letter of the image's extension and add a "w" (eg. .jpg>.jgw). Another convention is to append the image's extension with a "w" (eg. .jpg, .jpgw).
When opening the file, the Image Properties dialog will automatically enter the coordinates from the World file in the editable  (Drawing) fields.
www.youtube.com/watch
Background File Locations
The Standalone platform expects  background files such as Shapefiles to be stored in a local folder or network drive. If you are trying to store your background layer files in a central location, here are some possible alternatives/workarounds:
1) Use a file server (network drive)
2) Consider Bing Maps backgrounds, which can now be overlayed automatically after specifying the model Coordinate System.
3) Use the ArcGIS Pro integrated platform and add backgrounds via ArcGIS Online
MrSid files are not available as a background layer type
Consuming ContextCapture production files within your hydraulic model
