| Product(s): | WaterSight |
| Version(s): | 10.00. |
| Area: | Documentation |
After an aspect or consequence (using decision tree or predefined aspect method) or cumulative is created, results can be displayed in a map together with more information in the right side panel.
To access the results, just click on the more (...) button located on the bottom of the aspect/consequence or cumulative card (in either Likelihood or Consequence of Failure pages), and then select Results.
A new window with the results on a map will get displayed.
Map
Pipes will appear color coded in the map based on the grade colors defined previously in the Likelihood or Consequence of Failure pages.
Search for Pipe ID or label
Using the search tool located on the top left it is possible to search for a specific pipe ID (example below).
Bar chart
In the lower left corner a bar chart is displayed with the pipes length or number of pipes per each score.
Displays the map legend, with the identification of the number of pipes and pipe length within each grade.
Right side panel for the Predefined Aspect or Cumulative
Right side panel for the Decision Tree Aspect
Clicking on the Grade
The user can drill in into more detail, by clicking in each grade located on the right - side panel. When clicking in a specific grade, more information about the number of pipes and length for each score within each grade is displayed. Map is also updated accordingly with the selected filter.
Clicking on the Score
It is also possible to click in the score for more detail about the exact pipes ID that are included in each score. For the predefined aspect, besides the ID also the value used to score that pipe is displayed.
The user can export all the information and results to CSV for all pipes by clicking in the more (...) button located on the top of the side panel. This is useful for the user to be able to do further analysis.
Information exported includes Pipe ID, Score, Grade Name, value (for the predefined aspect), and length.
