H= Gutter Height
B = Width (Parabolic Gutter)
a = linear term coefficient derived with equation: a = 2H/B
b = quadratic term coefficient derived with equation: b=H/B2
| Product(s): | StormCAD, CivilStorm, SewerGEMS |
| Area: | Modeling |
The following shapes are available to select when modeling a gutter at a catchbasin:
This article explains the assumptions and use of each.
A conventional gutter begins at the curb and extends to the roadway centerline. The HEC-22 manual declares two types of Conventional shaped gutters: uniform and composite. Gutters having irregular cross sections have a gutter cross slope uniform to that of the road cross slope. A conventional gutter where the section nearest the curb is depressed compared to the roadway slope should be modeled as a composite gutter section.
Uniform (depressed gutter = false)
Composite (depressed gutter = true)
Where:
Q = flow rate (m^3/sec, ft^3/sec)
Kc = 0.376 SI, 0.56 US Customary
n = Manning's coefficient
Sx = Pavement cross-slope (m/m, ft/ft
SL = Longitudinal pavement slope (m/m, ft/ft)
T = Width of flow/spread (m, ft)
See more in Help chapter "Conventional Gutters"
Where:
W = Bottom Width (Ditch)
SL = Left side slope
SR = Right side slope
Where:
H= Gutter Height
See Hydraulic Engineering Circular No. 22, Third Edition Urban Drainage Design Manual (2009) for more details.
The Equivalent cross slope (Sx) for V-Shaped gutter is found with the formula:
where:
See more details in the Help topic "V-Shaped Gutter Cross Section"
