Product(s): | WaterGEMS, WaterCAD, HAMMER, SewerGEMS, SewerCAD, StormCAD, CivilStorm |
Version: | 10.XX.XX.XX, 08.11.XX.XX |
Area: | Installation |
User gets error: Registry key not found. Key = 'SOFTWARE\Microsoft\NET Framework Setup\NDP\v3.5'
OR Microsoft .NET Framework - Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempts to continue.
Error HRESULT E_FAIL has been returned from a call to a COM component.
This framework error can be resolved by an update to the .NET framework 3.5 SP1. If you have trouble installing .NET Framework 3.5 SP1 please contact Technical Support
