| Product(s): | OpenFlows Water (WaterGEMS, WaterCAD, HAMMER) OpenFlows Sewer (SewerGEMS & SewerCAD) OpenFlows Storm (StormCAD, CivilStorm, PondPack) OpenFlows Hydraulic Toolset (CulvertMaster & FlowMaster) |
Bentley Systems has published the following books on hydraulic and hydrology and water infrastructure engineering:
Electronic versions of some of these books are available at no extra cost using the links above.
Physical versions of the books can currently be purchased through our Amazon bookstore (U.S., Canada and Mexico - note: limited availability): https://www.amazon.com/s?me=A118I73O7BLO9K&marketplaceID=ATVPDKIKX0DER
Academic licenses available via the Bentley Education program
| New Product Name | Tier included | Included Application functionality | Installation Settings | Feature Level Maximum |
| OpenFlows Water | Advanced | WaterCAD | Choose Advanced tier, select from WaterCAD, WaterGEMS, and/or HAMMER | 5,000 pipes |
| WaterGEMS | Choose Advanced tier, select from WaterCAD, WaterGEMS, and/or HAMMER | 5,000 pipes | ||
| HAMMER | Choose Advanced tier, select from WaterCAD, WaterGEMS, and/or HAMMER | 5,000 pipes | ||
| OpenFlows Sewer | Advanced | SewerCAD | Choose Advanced tier, select from SewerCAD and/or SewerGEMS | 5,000 pipes |
| SewerGEMS | Choose Advanced tier, select from SewerCAD and/or SewerGEMS | 5,000 pipes | ||
| OpenFlows Storm | Advanced | StormCAD | Choose Advanced tier, select from StormCAD and/or CivilStorm | Unlimited Inlets |
| CivilStorm | Choose Advanced tier, select from StormCAD and/or CivilStorm | 250 links | ||
| PondPack | Separate installer from OpenFlows Storm, will install PondPack only | Unlimited ponds | ||
| OpenFlows FLOOD | Not Applicable | FLOOD | Separate Installer for OpenFlows FLOOD | Not Applicable |
| OpenFlows Hydraulic Toolset | Not Applicable | FlowMaster | Separate Installer for FlowMaster | Not Applicable |
| CulvertMaster | Separate Installer for CulvertMaster | Not Applicable |
If you are an educator (professor), solution guides for the first five books in the list at the top of this article are available by contacting Bentley Technical Support. These have the answers to the problems in the book.
For the book "Water Supply and Wastewater Removal", you can access the solution manuals from the publisher's website. Click the "for instructors" link, click "visit companion site" under "instructor resources", click "browse by chapter" > chapter #, then click "solutions manual".
OpenFlows Academic Book Software Installation and Licensing
(Blog post) Books
