| Product(s): | WaterCAD, WaterGEMS, SewerGEMS, SewerCAD, StormCAD, CivilStorm, PondPack |
| Version(s): | All |
| Area: | Modeling |
Can Bentley Support check my model and tell me if it is correct?
Can Bentley provide a consulting service to review hydraulic models?
Bentley Technical Support can assist with specific questions or problems that you may have. For example if you do not understand why the model is producing a certain result, Technical Support can explain the model assumptions for the specific case so that you understand why it is showing the result that you are seeing. Or, if you are seeing a specific problem, we can help resolve it or explain why it is occurring. Technical Support can also inform you of any "red flags" (obvious issues) with the model which you may need to check more closely, but it is not possible for us to find all problems without having a detailed understanding of your system, constraints and/or source data quality.
Bentley does have a Services team but in general Bentley cannot tell you if your model is "right" as that would require in-depth knowledge of the existing system (including topographical data and on-site observations for example) and/or knowledge of the design constraints specific to your project. Providing engineering advice would be a legal liability. It is up to you as the engineer to use the hydraulic modeling software to make engineering decisions, which will require a firm understanding of how the software works and any assumptions related to the software features that you use.
Similarly, Bentley Support cannot help you calibrate your model or tell you why your Darwin Calibrator results are not closely matching your field measurements, as this can take a great deal of detective work and requires a deep understanding of the system and its operations. Technical Support can answer questions about how to use Darwin Calibrator and look for any obvious issues.
If you are encountering a specific issue or question that you need assistance with, contact Technical Support by posting on our active forum (which is monitored by Bentley support and enables you to potentially get multiple answers from different viewpoints) or by submitting a Service Request.
Beyond this, if you do not have time to learn, understand and perform the hydraulic modeling yourself with adequate confidence, consider contacting an outside engineering consulting company to perform the hydraulic modeling.
There are many resources to help you learn and understand the software so that you can be more confident in your hydraulic modeling. See the "New User Learning Resource Guide" link at the bottom of the OpenFlows Wiki Homepage corresponding to your product, for a list of learning resources.
The OpenFlows products also have many tools and features to help you check your model for issues such as connectivity or other obvious issues. Some examples can be seen in these articles:
Lastly, if you are seeing hydraulic results that you do not believe look correct, consider the following quick advice:
