Product(s): FlowMaster, StormCAD, SewerGEMS, CivilStorm Version(s): CONNECT Edition, V8i Area: Modeling
For a Slot Inlet, where do I enter the sloth width and how is it used?
How do I solve for slot width for a slot inlet in FlowMaster?
In FlowMaster, you can only solve for the slot length which is typically of much greater concern, and the slot width is assumed to be adhering to the standard mentioned above.
In StormCAD, SewerGEMS and CivilStorm, if you have a non-standard slot inlet (that does not conform to HEC-22), consider using one of the rating curve options to model the inlet capacity and account for any differences from variations in slot width. See Modeling Custom Inlets Using Inlet Capture Curves
