| Product(s): | Bentley WaterGEMS, WaterCAD, SewerGEMS, SewerCAD, StormCAD, CivilStorm, PondPack | ||
| Area: | Output and Reporting |
Is there a way to save the model plan view as an image file such as JPEG, BMP, TIFF, PDF or a CAD drawing such as a DXF or DWG?
There are a few options:
Open the preview window by going to File > Print Preview. From the preview window, go to File > Export Document > Image File. You
will be able to save the file as a number of different image types.
Go to File > Export > DXF. Then, open the DXF file in another application such as MicroStation or AutoCAD and export from there.
Use the PrintScreen / PrtSc button on your keyboard to take a screenshot of the plan view, then open an image editing application such as Microsoft Paint, paste, crop as needed, then save as an image file.
Once exported via the Export Document tool, you can open the generated file in an image editor and export it to PDF format.
Poor quality when printing to PDF
