User Notification: The structure invert xxxx ft is lower than the headwater minimum elevation xxxx f
Product(s):CivilStorm, SewerGEMS, PondPack
Version(s):CONNECT Edition
Area:Modeling
A user notification is generated when computing a rating table: The structure invert xxxx ft is lower than the headwater minimum elevation xxxx ft.
This user notification means that the invert elevation for an element in the composite outlet structure is lower then the minimum headwater elements of the pond. You will want to review your elevation data to be sure the information is correct.
