| Product(s): | SewerGEMS, CivilStorm, StormCAD, SewerCAD |
| Area: | Output and Reporting |
Can I customize the annotation table seen at the bottom of the profiles? (the screenshot below shows the "Engineering Profile" style)
Starting with the initial CONNECT Edition release, engineering profiles have the option to include an annotation table which is drawn similar to the analysis profile.
The displayed fields and field order can be edited in the engineering profile which makes it more customizable. (for a subset of specific fields)
To toggle the annotation table display, click on the down arrow next to the Chart Settings icon and select "Show Profile Annotation Table" from the dropdown menu.
The annotation table options can be edited by selecting "Profile Annotation Table Options…" from this dropdown menu. This is currently limited to a specific subset of fields.
Changes made to the annotation table options (mentioned above) apply to all profiles in the current model.
The "Save Annotation Definition Settings as Default" option will not currently save the profile annotation table options for use with other models. If you would like to set up and utilize custom profile annotation table options with other models, it suggested that you set them up in a Seed File and "Start from seed" when creating a new model.
In the V8i versions (08.11.XX.XX) the profile annotation table cannot be customized.
For reporting of results, the Engineering Style profiles should be used. Engineering profiles can be fully customized in terms of annotations. To access engineering profiles, right click on the name of your profile in the profile manager and choose Engineering Profile. For more information, see the Engineering Profile help topic, and the other resources in the "See Also" section below.
[Enhancement # 295583]
What's new in SewerGEMS CONNECT Edition
