| Applies To | ||
| Product(s): | StormCAD, WaterGEMS, WaterCAD, SewerGEMS, SewerCAD, CivilStorm, HAMMER, PondPack | |
| Version(s): | 08.11.XX.XX and higher | |
| Area: | Output and Reporting |
Is it possible to create and share a FlexTable that a user on another computer can also use?
Yes. There is a category of FlexTables called "Shared" which will be available for all models on the same computer.
First, open the FlexTables manager. Create a custom FlexTable under the "Tables - Shared" by right-clicking on "Tables - Shared" and selecting the New button. This will open a new dialog box.
Set the Table Type to the element you want to use. Note that shared FlexTables are just like the predefined FlexTables in that the properties of one element cannot be displayed in the shared FlexTable of another. For instance, you cannot see node elevation in the pipe shared FlexTable.
The available columns for your new FlexTable will be in the list on the left. Highlight an attribute and click the Add button to include a property into the shared FlexTable. When you are done, click OK. The table will open and you will see a new FlexTable listed in the FlexTables manager.
Now, close the program and reopen it. Open any project or start a new one and the custom shared FlexTable should still be there. This is because this FlexTable is shared among all hydraulic model files that will be used on this workstation.
NOTE: You can also create a custom FlexTable under "Tables - Project". A hydraulic model level FlexTable will only be available for a single hydraulic model file. In other words, if you opened a second hydraulic model file, the FlexTables associated with the original hydraulic model file will not be listed.
The shared FlexTable is available for any hydraulic model on the current workstation, but it will not be available for another user automatically. If you want to share the custom FlexTable with a user who is on a different computer, use the following steps:
1) Open Windows Explorer and browse to C:\Users\(user name)\AppData\Local\Bentley\(product name)\10. The last folder name will be 8 if you have the V8i installation of the product.
2) Find the file called "FlexTables.xml"
3) Copy the FlexTable.xml file to the same location on the other computers. You can copy them onto a flash drive or save to a network location available for other workstations.
When you have copied the file, the same shared FlexTables will be available on that computer. Note: You can store the XML file on a network drive for other users to access, but the file must be saved to the local machine in order to use it at this time.
If multiple different users (on different computers) have their own set of shared FlexTables (and Flextables.xml file), you may want to have a "master" set of standard FlexTables from the combination of these multiple sources. Although multiple Flextables.xml files cannot be read in at the same time, you can merge shared FlexTables with the following method:
In OpenRoads and OpenSite, the "drainage and utilities" functionality (formerly known as Subsurface Utilities or SUDA) uses the same Flextables functionality and has two sets of FlexTables - one set for all utility types (gas, electric, water etc.) and one for drainage elements only (i.e. storm and sanitary). These are shown on two tabs in the FlexTables dialog - called 'Utilities', and 'Drainage.'
The shared flextables XML file (containing the Shared Flextables) for Utility elements is called SharedFlexTables-SUE.xml and is located in the subfolder of the SUDA user profile folder corresponding to your version. For example:
The shared flextables XML file (containing the Shared Flextables) for Drainage elements is called SharedFlexTables-SUDA.xml and is located in the subfolder of the SUDA user profile folder corresponding to your version. For example:
After setting up your standard Flextables on the first computer, deploy the xml file to all other users per the folder path above.
An alternative method of sharing FlexTables for the Drainage and Utilities functionality in the Civil products (OpenRoads, OpenSite, OpenRail) is to set them up in the 'Tables - Hydraulic Model' section, in a DGN Library, instead of the 'Tables - Shared' section described above. Your workspace should already include a library that sets up Drainage and Utilities content (feature definitions, prototypes etc) and you can add FlexTables to this. When you create a utility model in your working DGN, content from the DGN Library is copied across from the DGN Library, including any FlexTables in the 'Tables - Hydraulic Model' section.
Note that for the FlexTables on the 'Utilities' tab, you need to define the SUE_SEED_MODEL and SUE_SEED_FILE config variables, to point to the DGN Library and the model within it. These two variables work in the same way as the SUDA_SEED_MODEL and SUDA_SEED_FILE config variables that should already be defined in your config file.
NOTE: There is an open enhancement request (548533) for storing the flex tables .xml files at a central location, such as a network drive or ProjectWise, so that updates can be done there and all users point to this location within the team. Currently flextables rely on manually copying files to other locations for sharing purposes.
