| Product(s): | SewerGEMS, CivilStorm, StormCAD | ||
| Version(s): | CONNECT Edition, V8i | ||
| Original Author: | Mark Pachlhofer, Bentley Technical Support Group |
How is flow balanced at junctions with the GVF Rational Solver (StormCAD)?
Because of the use of rational method hydrology, flow discontinuities may be noticed. This is a condition where the sum of the inflows does not equal the sum of the outflows. The main reason for this is that the rational method is only concerned with peak flows and has a high dependence on duration (system time). As the system time changes, the intensity changes and has a direct effect on the rate of flow in the system.
The most common cause of confusion with this discontinuity stems from rational loads that are tracked through a long piping system without any other loads entering the network. At the inlet of origin, the time of concentration may be relatively small, resulting in a high intensity and a large peak discharge. As the load travels through the pipes, the system time becomes larger, so the intensity lowers. This results in smaller discharge values, so the peak flow at the outlet may be significantly smaller than the peak flow at the original inlet.
This may seem counter-intuitive at first, with questions like "Where did the rest of the flow go?" coming to mind. In reality, the rest of the flow was not lost, but an attempt to balance peak flows is not valid. Picture standing at the top of a hill with a bucket of water. If you empty the entire bucket into the gutter in one second, then the peak rate of discharge at the top of the hill is one bucket per second. Racing to the bottom of the hill, you can observe the flow and see that the peak flow is much less than one bucket per second. However, the flow lasts longer than one second. There was no water lost, but the peak was lower.
StormCAD does not simply add flow at a junction node; rather, it takes into account the attenuation of peak flow as one moves downstream by keeping track of upstream catchment properties and decreasing the peak intensity according to the time of concentration and travel.
The flow out of a catchment is:
Where:
Q = Flow
C = Coefficient
i = Intensity
a = Area
And the flow out of a junction is:
Q (out) = Sum (C * i * a) + Sum (Q known)
One would think therefore that flow in equals flow out. However, the intensity (i) used for determining the flow into the manhole will be higher than the intensity of the flow leaving the manhole.
This intensity is calculated using the longest possible flow travel time in order to generate the most conservative value for peak flow. For example, say a catchment empties into a catch basin and has a Time of Concentration of 10 minutes. On the other hand the travel time of the piped flow getting to the catch basin is 12 minutes. The rational flow generated at the catch basin will be generated based on the intensity associated with the 12 minute duration. This way you are assured that the whole system is contributing to the flow and hence you are using the most conservative peak flow value at that point.
If you do not wish to have this flow attenuation taken into account, you should specify Known or Additional flows at the catch basins.
If this situation occurs in a Carrier Pipe (multiple pipes in series, with no catchments connected to nodes along the pipes), you can also use the "Ignore Travel Time Increase in Carrier pipes?" Calculation option. This allows the modeler to eliminate the flow reductions that would otherwise occur as a result of the increased system time in these cases.
The purpose of this calculation option is to prevent a flow decrease in the downstream direction when there is no increase in the total catchment area, due to the increase in system flow time that would normally occur.
If this option is set as "True", the solver will not increase the system flow time when computing rational method flow for a “carrier pipe” (i.e., conduit with an upstream node having only one incoming conduit and no directly connected catchment area). The time used to compute flow in the carrier pipe is taken as equal to the system flow time used by the conduit immediately upstream of it, which means their flows will also be equal.
Carrier pipes can occur in series, with the same system time (and thus rational method flow) for all of them.
Note that flow times are only ignored when computing flow in the carrier pipes themselves. Once additional catchment area is introduced at a node downstream, the usual system flow time calculation resumes for subsequent conduits and will include any previously ignored upstream travel time(s).
For more on this including illustrations, see the section in the Help called "Carrier Pipes".
There is also an option to correct for partial area effects - the "Correct for Partial Area Effects?" calculation option. When set to "true", when two or more rational flows enter a single node, the GVF-Rational (StormCAD) solver will adopt the system time that produces the largest rational flow. A larger 'partial area' flow will be carried downstream until the 'total area' flows exceeds it. Further explanation including diagrams can be found in the help documentation, under Theory > Special Considerations > Partial Area Effects.
Note: starting with CONNECT Edition Update 2, the partial area effects option has been improved.
Flow Attenuation - Why does flow or velocity sometimes decrease when moving downstream?
Why is the system time at one of my nodes much larger than the upstream nodes Tc or system time?
