Do the OpenFlows products use MSHTA.exe files or other files with a .HTA file extension?
Product(s):WaterGEMS, WaterCAD, HAMMER, SewerGEMS, SewerCAD, CivilStorm StormCAD
Version(s):CONNECT Edition
Area:Other
Do the OpenFlows products use MSHTA.exe files or other files with a .HTA file extension? If so, what purpose does it serve?
Bentley uses a file called "manageExceptionLogs.hta", which sends crash telemetry to Bentley’s servers and manages the local log files. If needed, this file can be disabled. If it is, this would also disable crash telemetry. If there are errors generated when using the program, you would need to reach out to Bentley Technical Support for assistance with the error message.
Locating OpenFlows product error log file
