WaterSight - Tank Level (Schematic Overview)
Product(s):WaterSight
Version(s):10.00.
Area:Documentation
Select how to display the Tanks information
 Tank level Graph Overview
 Tank level Schematic Overview (this page)
The Tank Schematic Overview provides an at-a-glance indication in real time if tank levels are above or below minimum or maximum values defined (for the last 15 minutes average).
If tank level is below the low alert value defined in the Alert triggers page, it will appear color-coded with a red colour. If tank level is above the high value defined in the Alert triggers page, it will also appear color-coded with a red colour.
Note: the low and high alert triggers considered for the tanks are those configured based on the absolute trigger type.
The low and high level alerts values are automatically displayed in the tooltip when hovering the tanks schematics. The average value is represented by a dash line and corresponds to the expected tank level for the current time step (obtained based on the percentile 50 of the level historical data) while the real tank level and percent full for the current time are shown below each tank .
Current System Storage
Displays information about the current total system storage (considering all tanks)
Volume
Dropdown button allows to choose between volume information or level information . The tanks scheme information gets automatically updated based on this selection.
Comparison
Click here to compare tank variables between different tanks. More information here.
Sort by
When there is a long list of tanks, the user may find useful to sort tanks by name or by condition (tanks below or above min. and max. values defined will appear first) or search on the list by the name of the tank.
Tags
See the tanks displayed by user defined groups. User defined groups or Tags are defined in the Tank Configuration, under Administration. Please note that if no Tags are defined under zones administration, this field does not appear.
Search
Filters the list of sensors to the ones containing the word fragment typed in (case-insensitive).
For more information about WaterSight, please go to OpenFlows WaterSight TechNotes and FAQ's.
