| Product(s): | StormCAD, CivilStorm, SewerGEMS |
How is the clear opening area of a grate inlet determined?
The clear opening area of the grate is based on the grate length, width, opening ratio and clogging factor. These are multiplied together to achieve the effective opening area (see example further below) which is used when a grate is operating at higher depths where orifice flow controls.
The opening ratio is an adjustment based on the type of grate, which reduces the effective clear opening area. HEC-22 defines an opening ratio for each grate type, and the grate type is selected in a dropdown in the Inlet Catalog. See Chart 9A and Chart 9B near the end of the HEC-22 manual for the ratios used for each of the grate types.
You can see more information about the HEC-22 inlet equations in the "Theory" section of the Help documentation.
| Grate Type | Opening Ratio | Description |
| 30° & 45° tilt bar | 0.34 | Tilt-bar grate with transverse bar spacing 102 mm (4 in.) on center. |
| Curved vane | 0.35 | Curved-vane grate with longitudinal bar spacing 82 mm (3.25 in.) on center and transverse bar spacing 114 mm (4.5 in.) on center. |
| Reticuline | 0.80 | “Honeycomb” pattern of lateral and longitudinal bearing bars |
| P-30 mm (P-1-1/8") | 0.60 | Parallel bar grate with bar spacing 29 mm (1.125 in.) on center |
| P-50 mm (P-1-7/8") | 0.90 | Parallel bar grate with bar spacing 48 mm (1.875 in.) on center |
| P-50 X 100 mm (P-1-7/8"-4") | 0.80 | Parallel bar grate with bar spacing 48 mm (1.875 in.) on center, and with 10-mm (0.375-in.) diameter lateral rods spaced at 102 mm (4 in.) on center |
See pages 381-385 of our Stormwater book for illustrations of these standard types.
Furthermore, the Clogging Factor property is an additional adjustment to the effective open area. See more here:
For example if you have a curved vane grate inlet with a length of two feet, a width of two feet and clogging factor of 20%, the effective open area would be 2 * 2 * 0.35 * 0.8 = 1.12 ft^2
Note that as of version 10.04.00.158, grate, ditch and combination inlets assume a clear opening ratio of 0.90 (the P-50 grate type) when operating in-sag with orifice flow (higher gutter depths). So, changing the grate type will not change the results in such cases. This is planned to be fixed for the next release (reference #1177196) In the meantime, you can use the second option above to achieve the same effective hydraulic results.
Which dimensions are used when inputting grate information for inlets in StormCAD ?
