| Product(s): | OpenFlows FLOOD |
| Version(s): | 10.03.XX.XX |
| Area: | Modeling |
This article describes the main necessary steps to set up an oil spill simulation using OpenFlows FLOOD's MOHID Water engine.
To setup an oil spill, first create a workspace and then a new domain, selecting MOHID Water as the numerical engine. Then create a new simulation and add the Lagrangian module to the list of modules in the simulation. Then, in the Model input data options, set the option "Enable Lagrangian Module" to "True". Setup the Lagrangian module, defining an "origin" (i.e. a source or emission of particles representing the oil spill).
The Lagrangian module is organized by “origins”. An “origin” represents an emission source of Lagrangian tracers. An emission can be instantaneous or continuous and a simulation can have one or more “sources”. An example of an origin (emission source) is an oil spill, where various Lagrangian particles/tracers are emitted and transported by currents and winds.
The configuration file of the Lagrangian module contains a specific structure. In the configuration file there are global keywords, which define options applicable to all defined “sources”, and specific keywords, referring only to the characteristics of each individual “source”. The configuration of these options is done by aggregating “keywords” in a block (or more) blocks by a “tag” at the beginning <BeginOrigin> and another at the end <EndOrigin>, as shown below.
<BeginOrigin>
ORIGIN_NAME : Oil spill
<EndOrigin>
Each <BeginOrigin>/<EndOrigin> block corresponds to an origin, the number of origins being unlimited.
Next, the “keywords” that can be changed to create a new scenario are indicated:
Another set of global options is related to how the Lagrangian tracers behave when they get close to the shoreline. In this case, MOHID allows defining a probability of a Lagrangian particle being retained on the ground (“beaching”) when it is at a distance lower than a predefined limit.
Once the global options have been configured, the specific options for each origin (or emission source) must be changed. These options are defined within a <BeginOrigin>/<EndOrigin> block where each set of options is similar for each origin but with different values (e.g. 1 origin with crude oil and another origin with diesel fuel, each in different positions).
For the specific case of an oil spill, the instantaneous “emission” type is normally used, which can be the special type Accident (“accident”). These options are defined by the “keywords”:
Other options specific to each source are the position of the spill source, the spilled volume and the number of particles to use the simulation, described below.
Activate the initial spread method:
ACCIDENT_METHOD : 1
Set the wind drag coefficient (as oil stays in the surface, its transport must account for wind)
WINDCOEF : 0.03
Then you will need to activate 3 properties (temperature, salinity and oil) inside the "origin" block as described below.
<<BeginProperty>>
UNITS : ºC
CONCENTRATION : 11
EQUAL_TO_AMBIENT : 1
<<EndProperty>>
<<BeginProperty>>
UNITS : psu
CONCENTRATION : 36
<<EndProperty>>
<<BeginProperty>>
UNITS : m3
CONCENTRATION : 1
EQUAL_TO_AMBIENT : 0
AMBIENT_CONC : 0
<<EndProperty>>
Finally, it is necessary to configure the calculation options corresponding to the oil weathering processes. To make this configuration it is necessary to know the type of hydrocarbon and its properties.
To do so, it is necessary to define, within the origin block <BeginOrigin>/<EndOrigin> , a sub-block <<BeginOil>>/<<EndOil>> as shown below:
<<BeginOil>>
OILTYPE : Crude
API : 21
POURPOINT : -30
MAXVWATERCONTENT : 70
<<EndOil>>
Below is a list of the main keywords that parameterize the oil weathering processes:
