| Product(s): | WaterSight |
| Version(s): | 10.00. |
| Area: | Documentation |
WaterSight enables near real time anomaly detection, by automatically triggering alerts whenever real sensor or zone measurements are outside the expected patterns or other user defined thresholds. The methodology used follows the below main steps:
Those real (resampled) time series are represented in the graphs by a back line filled with black, yellow and red dots.
Below is shown a real resampled 15 minutes time series (black color) with the raw data at green. It is possible to observe some of the cleanup that is automatically done by the software, where some bad data was removed.
Figure 1 - Raw data at green and real 15 minutes time series (processed) at black.
Patterns and confidence bands are represented in the graphs by a grey band.
Whenever real data (re-sampled) goes outside the pattern confidence bands (above percentile 95 or below percentile 5 of the pattern), an outlier is identified and the real value is color coded with a red circle. For more information about patterns or forecasts, please click here.
Figure 2 - Real resampled time series (back line with black, yellow and red dots) and pattern confidence bands (grey band).
Alerts can be automatically generated by the software based on user defined triggers or can be manually created directly from the graphs. There are four type of alerts that can be configured:
Alerts can be triggered to sensor or to zones.
In case the system is well sectorized in small DMAs (district metered areas), flow measurements exist at all zones inputs and outputs and there are several pressure measurements available inside the DMA, then all those measurements can be used to better geolocate the potential leak inside the zone, by: 1) configuring a flow increase alert for each zone, based on pattern type alarms and 2) configuring pressure decrease alerts for each pressure sensor, based on pattern type alarms. Whenever a flow alert is triggered for a zone, this can also generate a pressure decrease somewhere inside the zone near the burst location.
For more detail about alerts configuration, please click here.
Figure 2 - Example of an alert generated based on pattern deviation.
Generated alerts get automatically available in the Active Event List. These events should represent anomalies that are happening or that occurred in the network (such as pipe breaks, zone changes, fire, flushing, meter failures) and should be managed by the user.
Figure 3 - Active Event List
