| Product(s): | WaterGEMS, WaterCAD, HAMMER, SewerGEMS, SewerCAD, StormCAD, CivilStorm |
| Version(s): | 08.11.XX.XX |
| Area: | Output and Reporting |
After creating a Project FlexTable you may decide that you want to make it a Shared FlexTable without recreating it.
When creating a custom FlexTable you may want to use an existing one as a template.
Project FlexTables are only available in the file they are created in.
Shared FlexTables are available in all projects opened on a computer.
How can a user create and share FlexTables between different computers
